chevy2
- Herts.
Whoops!What did Robin Hood have to do with it... or was it Dick Turpin?![]()
Sh*t happens
I have the band saw, I think mines a Sealey one (its red!) and it must be nearly 20 years old.
I have added a few mods to the vice to cut short stock and also a jig to do a 8" long cut with the vice removed.
I bought a job lot of Lenox blades about 10 years ago from JL Industrial Supplies (now http://www.mscdirect.co.uk/cgi/insrhm) when they were on offer and I am still working through them.
Best tip is to set the vice to cut square and then use a jig to cut angles rather than resetting the vice to square each time.
Any pics of different jig setups? I have a few ideas, want to set something up for the rapidor to cut 45's.
Do you have the vice with the fixed front jaw and swivelling rear, or the one where both jaws can be swivelled?
It's the first one.
It's a doddle to set the movable vice jaw back to square once angled cutting is finished, with one jaw being fixed. Trying to angle the vice itself would limit the amount of angle available before the blade tried running into the vice.Same as mine then. I'd thought of, with that one, either using predefined angle blocks against the fixed jaw, (with a slight lip on the end of the block to locate it and hold it in place against the edge of the jaw, so that the block can't slide out of place when pressure is applied), then just loosening off the movable jaw and setting its angle via the block.
The other option I'd considered was using the length stop, (the holes with a clamping bolt which run at a right angle through the base of the vice), with some form of angle gauge clamped in there instead of a stop, then setting the movable jaw to the required angle using a parallel piece once the angle gauge has been set to the required angle. The first option would likely be the more sturdy of the two options though.
Hope those make sense? Ideas don't always transfer well from mind to print.It's a doddle to set the movable vice jaw back to square once angled cutting is finished, with one jaw being fixed. Trying to angle the vice itself would limit the amount of angle available before the blade tried running into the vice.
Heres mine, cuts up to 3" x 2" and mitres to 45degrees.
I've had my cold saw for over twenty years,
its the slow running toothed blade type and coolant fed if reqd,
no sparks or dusty crap everywhere,
blades only reduce in diameter over a number of years due to resharpening,
mine typically last several months without a sharpen with is around £7-8 each time,
I keep a spare as turnaround is generally a week
yes they definatly are, but whats the question please???
The evolutions are portable, and make a hell of a noise, the "band saw" a lot quiter, both set correctly should cut 45 degrees accuratly.
Stan
