- Birmingham
Set screws are that type as in the photo, with a full length thread? Assuming I read that link correctly, that is.![]()
You're right set screw is fully threaded, bolts have a shoulder (if they're long enough)
He knows that. He used to run a mail-order business selling bolting kits for Landrovers, but Post Office closures, car theives and Cornhill-Allianz conspired to put him out of business.
Lantern fixture/chuck.http://www.model-engineer.co.uk/forums/postings.asp?th=66771
Just a quick search, but you can make all the sections to suit each different requirement.
I am sure Sparey has a section on them. If required I can scan the pages tonight/tomorrow.
Are the designs for that in his Amateur's Lathe book, or some other other title? I have that one knocking about here if so, but if not I'd definitely appreciate those scans.
That looks like it could be a handy fixture in a multitude of ways.I've just seen 370 Kg of brand new UNF nuts & bolts go for £52.00, costmesomeone the best part of £1000 when new.![]()
The ones without the unthreaded portion are called full thread, as far as I know, the ones with this section are just called plain/regular/standard. You can get also shoulder screws where the unthreaded portion is a greater diameter than the thread if that helps.
Those shoulder screws would be usable at a push if only they did them with countersunk heads, which it appears they don't judging from that link?Local supplier is Thomas Graham and sons, they're based in Carlisle but have depots around Cumbria and Lancashire.
I'll try those if I don't have any luck with the others.Cheers.Are the designs for that in his Amateur's Lathe book, or some other other title? I have that one knocking about here if so, but if not I'd definitely appreciate those scans.
I think so, but now I have offered I will have to find mine.
Even if there is nothing there, the design is straight forward and you can make it however you want.
I will start the hunt.
Edit: Well that did not take long, but the bad news. Nothing there so it must be in one of the 163no MEWS magazines, and I can never remember which issues have the full contents.
I do not mind looking, but it may take some time.
If you happen to drop across it at any point though, I'll definitely take you up on those scans.Try Namrick, I use them for all my Imperial nuts and bolts
I'll add those to the list of suppliers I'll be badgering.
