Does the compressor run continuously ?I use a 3HP 50 litre compressor with a similar gun and also one that takes more air. You should be fine. Check your gun for air leaks. Sometimes the nut on the trigger comes loose.
Good setup, What type of hoses are you using ?Yes you can couple them together, that's what I did, I also coupled the electrics but that's not really necessary.
YepIs the small tap for turning off the air
as far as I remember the internal diameter of those taps is very narrow check it and if that's the case remove that aswell
The hose form the shed to the garage is 10mm as are the spraying hoses. The hose on my tool reel is only 8mm but it seems fine for my tools.Good setup, What type of hoses are you using ?
