The original post talked about the price in terms of room sizes, but now everyone is talking about floats?
I was under the impression this was internal work?
it is but pointing out dont buy or use cheap **** trowels and floats otherwise you will never master it properlyThe original post talked about the price in terms of room sizes, but now everyone is talking about floats?
I’m up for suggestions as to what kit I’ll need too. I do have a few bits and pieces but I know I’ll need more and am happy to buy whatever I need.The original post talked about the price in terms of room sizes, but now everyone is talking about floats?
If you are starting from bare brick you would be floating and ruling your scratch coat and float coat
I, personally, wouldn't, but that's not what i was really saying -
Discussion on what float is the best etc isn't too relevant for base coat. Its not like you're wanting or needing a visually uniform finish. You just want it straight, and then scratch it. Some fancy float or whatever is neither here nor there.
I would just trowel it up, scratch it, and leave it at that. I wouldn't see the point in floating it at all, as, if you cant trowel on the base flat enough to not disrupt the finish coat, then it will be hard to get the finish acceptable anyway. I mean, there's clearly nothing wrong with doing so, but I'm just not sure as id see the point? Certainly not enough to care about what float anyone was using anyway?
In truth, id not even bother scratching an nhl base for a putty top. Sharp will be plenty enough of a key, but it could be done either way, im sure.
Anyway...
My confusion was generated by the discussion of which float was best, when i thought it was an inside job. Im not telling anyone not to float it - just that i was beginning to doubt that it was an indoor job.
as long as the original plaster isnt touchedWell at least the horsehair to mix in the render will be free courtesy of Mrs Woz![]()
pre 1900 it could contain asbestos and anthrax and horsehair was told that when i started work over 50 years ago . worked in a fair few propertys with it .no masks then
im still ere so it didnt get meSorry, I’m away at the moment with no phone signal and WiFi that spends more time dropped out than in so gave up trying to reply last night.You may as well ask which fishing rod is best.
If i had to buy a single trowel, id go for a marshalltown MXS66D, but few other people would! It may well be a bit slim for carrying on a lot of material quickly.
Ha, I think I may recognise someone on there.The Period Property forum is the place to look for anything to do with lime plastering.
Period Property Forum
Lots of very experienced people of there who will advise the best mix for what you're doing. Ty-Mawr as mentioned above also get lots of recommendations on there.
Yep use one of those and vertical battens on the wall the same width as as a guide and you'll get acceptable results. A friend plastered her entire house using that method and it looked great.If you are crap at plastering (like me) you cant go far wrong using a Darby, gets you 90% to where you need to be before trowelling up.
Dot and screeds, traditional and only acceptable way to get a flat and level jobYep use one of those and vertical battens on the wall the same width as as a guide and you'll get acceptable results. A friend plastered her entire house using that method and it looked great.![]()
