123hotchef
- Kent
gotta be done I cant wait to play with them all tonight, I even splashed out and got the 9.99 sand blaster
I bought the saw, punched out the roll pin, and eliminated the spring loaded thingy on the trigger bar. Also bought a couple packages of the air fittings. The male to female thread contact on the fittings is very poor, a pi** poor fit for sure, and same with the saw; but I like the saw itself, especially at the price.I used on of the aldi air fittings on a regulator i had on the wall and it leaked air from the off. I got rid of it and bought a good one and the shed doesn't have the annoying constant hiss.
ok so been out in the garage testing the tools, the air sander is crap needs a push to get it turning thats going back tomorrow and the grinder has the nut and gland missing so that can go back too. The needle scaler is pretty useless even held it on to my hand didnt feel much so i tried it on the manhole cover would just about take the dirt off of it
Have you got the air turned up to 6BAR or a bit over? When I first plugged mine into my wall mounted dewatering/oiling fitting the output had been factory set to about 4 BAR. Definitely not enough to blast any medium.
Despite my previous statement, the Aldi extension hose has stopped leaking air. Also I've finished the outdoor sand blasting cabinet. Just the window to cut and fit and I'll take it for a test drive.
Bill, die filing machines & hand held filing machines don't lift on the return stroke,they stay in contact with the job all the time.Don't think it would be very good as it's not going to be practical (or even possible) to lift the file for the return stroke so it'll end up very blunt very quick.
