I'm starting to use mine to put nice rounded ends on angle & flat bar when I'm making brackets, etc.
I've a collection of thick washers I use as a guide to get the correct radius.
Lovely.
Nice to see that when somebody takes the care to do it.
I 'ates sharp corners on brackets.
I've just used mine in anger. Cutting the flange off of a 3.6m length of 6mm angle. I had to cut from both sides but very impressed with the performance. Taking the radius into account it was probably having to deal with 8mm.
Bloody hell thought it was Chris ReaI've just used mine in anger. Cutting the flange off of a 3.6m length of 6mm angle. I had to cut from both sides but very impressed with the performance. Taking the radius into account it was probably having to deal with 8mm.
do you need a licence for those shorts ,,, lol
need another lockdown to finish it all.
Won't be long then...
i will take the shorts view anyday compared to the mankini pic of a member
I have a question about powering of the Lidl plasma . As I have only 16Amp socket as standard in Czech, I hope that this can be powered using 3phase (3x240/400V) using 3phase oneway rectifier to get DC which should work, as the plasma has rectifier in the input of IGBT board. Does enybody here has any experience with this powering ? My goal is to split the input current 25Amps to 3phases.
