Seadog
Save the planet. It's the only one with rum!
- NE London - UK
In 2017 I finally got round to refurbishing my PortaPower that had been laying outside. I posted the rebuild of the pump on another forum so will just leave post the link in case anyone wants to read it
https://madmodder.net/index.php/topic,12276.msg146288.html#msg146288
There was also an annoying drip from the cylinder, but since it only gets used once in every other 5 blue moons I've never bothered about it. Due to the lockdown there has been a massive surfeit of Round Tuits so I've grabbed my fair share and set to on all manner of diverse and interesting repairs and builds.
One of these Tuits was assigned for fixing the leak.
It's a fairly simple matter to disassemble the cylinder. Being single acting, there is a retracting spring and this is retained with a 6mm machine screw which is accessed once the hydraulic coupling is removed. Remember this, because I didn't
the locking ring can then be unscrewed and the piston rod withdrawn. the seals are retained with a threaded collar, pretty standard practice I would imagine.
There wasn't much wear evident on the sealing lips so I cleaned and reassembled the seal and just tightened the collar down a couple more turns. When slid back into the cylinder there was some slight resistance whereas when I dismantled it it pulled out with virtually no effort.
Job done
Except, some time ago I did think of fitting a pressure to it, because I could. During one of my tidying sessions I came across a couple of pressure gauges that I'd bought when trying to fault find a problem on my Range Rover back in 2007. Well, there's no time like the present, let's do it.
In my dash to get it done I decided to mount the gauge diametrically opposite the input port...
Popped a pilot drill in, all well and good, but there was decidedly less metal to drill through than I had expected. Any guesses as to why?
All I'll say is return spring and screw
Oh well, it's all fun, isn't it?
I intended tapping it BSPT and to that end had worked out how to screwcut it on my Boxford since I don't have a die. Good old Zeus provided me with the tapping drill size (for BSPP
) which is 20 thou larger. At this point I should have stopped, had a cup of coffee and a think, but I didn't. Expecting BSPT, I was going to drill through and then tap. Since it was going to be BSPP, I could have drilled part way and then squared the bottom of the port to allow for a sealing washer on the face. Never mind, there are other ways to skin a cat, fortunately.
I don't like thread tape, unless there's no other way, so I decided to face the cylinder wall to allow seating for a copper or Dowty washer.
What did I do before I bought a boring head? It only has a limited range but it's more than paid for itself over the last couple of months. Once again the Progress was pushed into service as a vertical mill.
The question of how to hold the return spring was easily resolved. A hole was drilled at 90° to its original position, then counterbored and finally tapped. A handy 1/4" BSF machine screw was tweaked and the whole shebang reassembled with a copper washer as a seal.
Now to the question of how to mount the gauge. Usually It's stuck in the top of the cylinder but for a reason known only to my inner mind, I decided that I wanted it on the side. Now I needed a right-angled fitting, which I didn't have. But I did have a lump of cast bronze of unknown origin and composition, So I set to to make one.
And some more silver soldering action left me with this
And the finished article, except that I dropped the gauge during the day and it wasn't until I'd fitted it that I noticed a small problem
Oh well, it's just as well I have a spare
Job done
) which is 20 thou larger. At this point I should have stopped, had a cup of coffee and a think, but I didn't. Expecting BSPT, I was going to drill through and then tap. Since it was going to be BSPP, I could have drilled part way and then squared the bottom of the port to allow for a sealing washer on the face. Never mind, there are other ways to skin a cat, fortunately.I don't like thread tape, unless there's no other way, so I decided to face the cylinder wall to allow seating for a copper or Dowty washer.
