Walked in to that one. :-)haha, was supposed to be a jokehowever, it could work on a mercury based manometer..
I think the OP 'needs' to do a Rover V8, I suspect there'd be some interest on here![]()
I know some people have big budgets for their cars, and mine is pretty small, but for me its about the challenge of doing something and following my ideas, rather than having people telling me I cant do what I want to. So when I decided that I
so I fell across this web page
www.dwyer-inst.com/Products/AirVelocityIntroduction.cfm
and then I began to play. now I based my flowbench on 40mm plumbing fittings as they are cheap and easy to get hold of and larger than the ports I was wanting to test.
................................., it was to improve the driveability as Im a slow driver. what has been impressive is the increase in torque across the rev range, so the engine is smoother to drive and I can trudle about at in 5th gear at 1500rpm (but dont do it too often)
Hi Optima21 I sent you a message did you receive it?
A cracking engine.
you're equipment is too posh for my garage, with a vacuum station, stay away from dysons, they suck at sucking, even with all their technology ......a basic wet/dry workshop cleaner is best vac is best.....
this thread only started because of a comment on the thread about dyson vacs on here
ohh and if you want to know about flowbenches, many years ago I stumbled across this one
http://www.flowbenchtech.com/forum/
see you can have a forum for anything
dont think it would be too much of an issue, and the larger and smoother the bore the less the vacuum drop will beI have been looking at adding a flow bench into the mancave worktop, dont think I can or want to give one a dedicated space. If a decent vacuum pump was mounted in a box outside and piped in would the pumping losses be too great over say six metres?
Bob
