mine is the really old version...
25:1 on mine with stihl oil. Just come in from putting an hour on it padding beads in the horizontal and overhead with 7016, didn't miss a beat. To stop them, look on the pull start area/fan cover, there should be a rubber button that you press to kill the ignition.
I run 3.2 on 100-115-130 depending on joint type and position on mine. I don't use any other sizes of rod. Put up a photo of your control panel plate, you might have the fine adjustment version![]()
he has it running properly nowMake sure the petrol cap vent hole is not blocked ?
OP =ORIGINAL POSTEROP???
This conversion is not for your engine it is only for the seagull outboard.There's a conversion jet available for seagull outboards to go from 8:1 up to 25:1 with modern oils, and they don't seem to grenade themselves.
I think hugh was just giving an example that you can weaken off the oil ratio with modern oils??
I prefer mineral to snth for everything,engine oil etc, so is the stithl oil mineral??
