Yes That is the size I was thinking of.Yes, that is correct.
All the dims when you have them please!
thanks
Was it the shaft length you couldn't find or the motor frame/power? Didn't have spec with me but thought they were available.morning what are you using for the Z axis drive i cant find the one they recommend on amazon
yes it was the shaft length but i think i found it nowWas it the shaft length you couldn't find or the motor frame/power? Didn't have spec with me but thought they were available.
I haven't bought it yet as I drip feed the purchasing hoping she won't notice. But she will.
Just noticed my brother started a print for me but used infill. Does it need to be solid for strength?
Just an heads up. 3DQF should have some cheap PETG soon as they have installed a new machine that is able to extrude ABS, PLA and PETG.I've spent £32 on filament so far on 2 rolls of PETG and might go into a third given my track record of failures so if it was £72 all in that would be a no brainer - but as mentioned above the extra costs would be a consideration.
thanks
Yes I was definitely going to rig up an end support. Looks wrong without it.Scratch the above drawing, the bracket will foul the travelling X assembly at full reach, so will have to be on an end plate rather than the side, but you get the idea anyway.
Thanks for that, looks like a good method.There are some end supports available from harbaurghs workshop and made by dad on YouTube if you need stls or inspiration
who or what is Dad?There are some end supports available from harbaurghs workshop and made by dad on YouTube if you need stls or inspiration
This might give you a few ideas.T
I thought you could only get them via his patron channel?There are links in the description to the drawings and stl files.
Yes it does seem to be pretty similar. JD's has an additional two axes plus some kind of THC in the pipeline.Is it just me, or does JD's design have a lot of similarity to MbD's?
