As in add an additional boiler?dont forget if one wont cover the whole system then 2 systems can be used therefore if one fails there is another
yes 2 25kw boilers will still run your system
one can be used upstairs and one used for downstairs
a thermal store can also run both systems as one system as well
https://www.stovesonline.co.uk/wood_burning_stoves/Thermal-Stores.html
dazza can also answer your question on a thermal store being used as hes got a system already
his house is concrete built and large at that
http://www.mig-welding.co.uk/forum/...inder-thats-locked.72150/page-22#post-1091713
i could throw this into the mix
https://www.ebay.co.uk/itm/central-...199292?hash=item2a9b5d253c:g:8uQAAOSwOyJX9r7g
Mine 30 kw and use about 500 ltrs a year but we supplement ours with wood on the back boiler. And the house though a decent size is extremely well insulated.How much more efficient at these boilers i've gone thorough 500l in two months.
Sounds to me like you need lots more insulation in your house
Edit: Single glazing solid concrete floors and ceilings with no insulation and no carpets.
re: boiler sizing -
you have the quote from the company, right? what size unit did they spec for?
also, you have a list of the rads that they were going to install?
if you total up the output of the rads, and the hot tank, that should match up with the boiler.
Theres very little point in having some massive boiler if the rads you have it connected to can not dissipate that heat - all that will happen is that the boiler has to cycle all the time, which, in itself, is not a great idea. Or you run the coolant so hot in an attempt to shed the heat that the return is way above the distillate temp of water anyhow, so youre never in condensing mode, and you drop efficiency that way.
What im saying is bigger isnt just better - you want the boiler matched to the tank and rads. Sure, there may be a minor advantage in having a larger exchanger, and then jetting down the burner, but my advice is to try not to get sucked into thinking you need some vast monster.
measure your rooms and calculate your rads btu
its better to have a rad slightly oversized than under sized and the room feels cold
Ouch!How much more efficient at these boilers i've gone thorough 500l in two months.
Ouch!
I live in an old welsh cottage, because we wanted to keep the character we have slate floors & stone walls that aren't insulated, we've managed a little insulation in the roof and have double glazed windows. 1000L of oil usually lasts us 9 to 10 months including the winter and that's with a conventional non-condensing boiler.
How do you get through 500L in 2 months ? is your place huge or do you like it tropical 24/7 ?
