8ob
- Nescient in the vale
hard wire it in to a 45 amp double pole isolator switch if the charger doesnt get moved
Makes more sense, no plug/socket will last forever with constant plugging/unplugging
Bob
I could be missing something, but if you have to unplug something regularly then it stands that hardwiring it probably wouldn't work either.Makes more sense, no plug/socket will last forever with constant plugging/unplugging
Bob
120 vac is limited to 15 amps, and 20 amps with the different blade orientation.They are little screws so I doubt it. I just use the VFT method!
If 240V is bad I shudder to think how you lot cope with 120v. Give me 415v 3 phase any day![]()
Yes, I have read that here before.We only use 115v on construction site for hand tools. Using portable transformers.
Our grid power here is 1~ 230v 50Hz or 415v 50Hz ~3
I think it's 16amps but dying out fast due to battery tools. Not many people bother with them any more.Yes, I have read that here before.
So my question still stands, with the added legal verbage "On construction sites".
My forklift only gets charged about 6 times a yearMakes more sense, no plug/socket will last forever with constant plugging/unplugging
Bob
Common 240 vac outlets here are IIRC 30 and 50 amps.I think it's 16amps but dying out fast due to battery tools. Not many people bother with them any more.
Household supplies can go pretty high on 240v. Some electric showers are 40amp. House sockets are 13amp. Then you can get 16 and 32 amp sockets on 240v. Mine was a 32amp.
My ABB plugs say made in Germany. Maybe the pins were ChinaABB are Swedish
But in all honesty it's just a bad connection. On stuff like that it's worth a periodic check.
I've got Clipsal one in my garage that has got double screws for the cable clamps, but they were not cheap. I've connected them with a ferrule or without, doesn't seem to make a difference as long as it's tight.
If you want to try some ferrules I've got stacks of bigger sizes, I'm unlikely to ever use them all, I can post you some if you want (Obviously you need the crimpers to make the joint)...
Could be the surrounding plastic is defective.My ABB plugs say made in Germany. Maybe the pins were China
Thanks for the offer much appreciated!
In France it's common to have 3 phase to most houses.Common 240 vac outlets here are IIRC 30 and 50 amps.
I always wire 50 amp ones in my shop.
FWIW I have read that in the 1950's in Southern California, PG&E wired 3 phase into houses. Many are still set-up this way.
I have a couple of SNOW tapping machines, and they are 440vac 3 phase only, with a 1/2 hp motor and the other one is 1 hp...talk about low current draw.
That sounds too much like work, wrestling that anaconda in/out of the socket.you ca get 64amp 240v single phase sockets
can probably get 128amp, 64 is just the biggest I've seen
have a 128amp 3 phase socket at work
My forklift only gets charged about 6 times a year![]()
Oh I do. I baby my forklift. Never let charge go below 30%. Had it for 8 years now. Never had to add water to the cells either. Only had 1000 hours when I bought it. Now on about 1200You should keep it charged up and stick it on the charger now and again even if it doesn't need it.... Keeps the batteries healthy
We've had a, I think, 200A 3 phase connector. The cable was stupid, almost knocked my mate out when it flipped over due to a twist.That sounds too much like work, wrestling that anaconda in/out of the socket.
Do they have a cam handle that pulls it in and locks it ?
I did a re-design on a large 4 conductor special battery charging plug, and
it had a cam device to push it in and out of the socket.
63 amp and 125 amp in 4 or 5 pin. The 125 amp ones are a pig to plug in and out sometimes!you ca get 64amp 240v single phase sockets
There's still loads out there, we install hundreds of 7 & 10kva 3 phase transformers on site every year, lots of lighting and "power drop" where a line of the 110v sockets are strung along corridors.32A and 16A 110v sockets are the standard sizes, as already mentioned fast becoming obsolete due to the performance and convenience of modern cordless tools
