slim_boy_fat
- Scottish Highlands
When dismantling a chuck you should always put it back the same way, even the pinions should ideally go in to their respective locations. It is not just due to the original way it was but also because through time these parts will bed in and wear so putting back in a different position may upset things.
I'll be marking everything and placing them in their dismantling positions on a clean A3 sheet of paper.
. Might see if I can strip the chuck and put it through the ultrasound cleaner as a starting point - don't want to miss the TV, so it's a bit of a 'no-brainer,' to lapse into the vernacular.....
] so the parts are now enjoying a hot bath in the ultrasound cleaner. Initial examination reveals the first 'tooth' on jaw 1 is missing, so once all is clean I'll remove the scroll for close inspection, and to find where the missing tooth has gone. With any luck it'll have, at worse, got caught in the grease and will be in the bottom of the u/s tank, or lodged in the scroll without doing any damage.....so still fingers and everything else crossed until then.
But, probably not today.
Head cold's no worse so got out this morning to see what's what.
. I'll also check the scroll is completely flat but I think it's highly unlikely it could have been twisted out of shape in the episode. No major damage visible at a glance, apart from slight 'chewing' of the very outer 'feed-in' on the scroll which I'm sure I can dress up with careful filing. I'll report further when progress is made.
