Screwdriver
If you imagine putting box section in a vice corner to corner and then the same but with a triangle piece.... The box section is much easier to distort/squash than the triangle
I think it's all a bit if a mute point because whatever people do will be many times stronger than needed... But it's good to think about it and not just copy existing designs
Yes but you're never going to apply force in that direction on a press. This is what I was thinking:
If there is an offset to the force being applied and your concern is to support the edge of the C channel, then the angled insert will generate a bending moment around the long side of the triangle. Remembering the whole purpose of using C channel in all designs is to form an unsupported span.
Normally you would want the press to operate close to the vertical edge of the channel (in between the two spans of course) but on occasions where it pushes the far edge (straight down!) this was what I was getting at. It is a moot point because I don't think that is a particularly weak area in most constructions anyway but it's interesting to think what happens under the circumstances. As often as not, there will be a plate between those spans anyway.
