Have too admit I have never used a press, bearing heaters, hot oil baths, walk in fridges, oxygen acetylene, grinders and chisels, welding but never actually used a press.
My fab work is OK, I cut and welded the steel frame for my workshop, see here.I’d say go as big as you can afford, that way you’ve always got plenty of head room should you need it.
Sometimes wheel bearings can be stubborn and “10 ton” may not be enough. I would be looking at a 20t at least. What are you fabrication skills like? You can easily knock a simple press together provided you’ve got so workshop equipment. I made a bench mounted 25t press a bit back and I’m embarrassed to say I haven’t used it yet... but it was substantially cheaper to make than to buy
The amount of mucking around it takes with presses sometimes I think I'll stick with what I do. Plus we don't have them at work never seen one on a ship.You don't know what you're missing. You should buy one immediately.
I didn't know they are not standard on a ship. I would have thought they were indispensable in a workshop. I suppose there is the issue of space? What equipment is typical in a ships workshop if you don't mind me asking?The amount of mucking around it takes with presses sometimes I think I'll stick with what I do. Plus we don't have them at work never seen one on a ship.
No real space constraints just other methods are easier and quicker. Not much to be honest, a pillar drill if it's not broken, a lathe if it's not been totally screwed and broken, 2 bench grinders and a couple of work benches and 2 or 3 vices, oh and a donkey saw or horizontal band saw (if the company is feeling flush) or cheap abrasive chop saw, a unitor rebadged ancient and out dated miller or other brand transformer 440 stick welder, sometimes we we have a fancy electronic one but they are rare outside of new builds and a little 150amp portable 220v buzz box. And that's our lot.I didn't know they are not standard on a ship. I would have thought they were indispensable in a workshop. I suppose there is the issue of space? What equipment is typical in a ships workshop if you don't mind me asking?
Cheers, that has blown my illusion of a fully stocked state of the art workshop then!No real space constraints just other methods are easier and quicker. Not much to be honest, a pillar drill if it's not broken, a lathe if it's not been totally screwed and broken, 2 bench grinders and a couple of work benches and 2 or 3 vices, oh and a donkey saw or horizontal band saw (if the company is feeling flush) or cheap abrasive chop saw, a unitor rebadged ancient and out dated miller or other brand transformer 440 stick welder, sometimes we we have a fancy electronic one but they are rare outside of new builds and a little 150amp portable 220v buzz box. And that's our lot.
Yeah its pretty basic, there's an electrical test bench station too and a few hand tools, cheap home owner grade grinders and drills sometimes get battery tools but they are as rare as hens teeth. Have some air tools but usually hopelessly worn out and destroyed so quicker and easier too use spanners, ratchets are usually all missing or broken. Not many usable hand tools at all. Usually all broken mangled or lost. There is an awful lot of just trying too manage/come up with ways too get by without.Cheers, that has blown my illusion of a fully stocked state of the art workshop then!
The general rule of thumb used to be if you cant solve it with a hammer and a gas axe, then it’s an electrical fault....Cheers, that has blown my illusion of a fully stocked state of the art workshop then!
Yeah, thats what I thought they looked like. Glad I stayed on the landMaybe the US navy might meet your expectations better
Ah but I started as a mechanical engineer then swapped after twenty years to electrical..... So its probably my fault anyway!The general rule of thumb used to be if you cant solve it with a hammer and a gas axe, then it’s an electrical fault....
