scarecrow
Outstanding in his field
I was thinking of attaching the plate that the springs are hooked into to the top plate of the jack rig, and having a compression spring as well like in the design in the pic.
I was also thinking that the hydraulic pump part of the jack looks like it is screwed into the base on the side, So was looking to remove it and mount it on the side of the upright and connect it to the jack with a hydraulic hose.
if you use a compression spring you don't need to attach the jack to anything as the spring will hold it in place and you can easily take it out and use it for jacking
i don't see the need to move the pump just put a longer hose on the trigger and attach it to the bace
