At least you can replace bits of the system, on some Freelanders you have to buy a complete replacement system
You have to pump fluid in through the bleed nipple.
and ive bled it syringe
Some old cars with short slave cylinders where adjustable to account for the limited travel but it doesnt alter the bite point, that is set by the hydraulic ratio.Never seen an adjustable hydraulic clutch.
That clutch sounds fine to me, it's self adjusting in itself, and you can't change that with washers or spacers, it will remain the same unless you use a larger master cylinder or smaller slave cylinder, then your looking to do damage to your cover plate by over pressing, been there and got the tshirts lol
Adjusting the slave will do nothing, you would have to adjust the master cyl rod, but if, there is virtually no play in the rod, then you cannot adjust it, it has to have some free play to allow the master to pass fluid back into the reservoir when your foot is off the clutch.what if when the pedal is slammed on the floor theres still some more to go on the m/c rod ?
appreciate all the replies folks
PS as said it is the master cyl that controls the clutch diaphragm movement that is where you need to be looking.Adjusting the slave will do nothing, you would have to adjust the master cyl rod, but if, there is virtually no play in the rod, then you cannot adjust it, it has to have some free play to allow the master to pass fluid back into the reservoir when your foot is off the clutch.
This may seem mad but have you checked the carpet or the floor for damage, under the pedal or the pedal pivot bushes, I had a problem with one that had carpets put under the normal carpets which was enough when a new clutch was fitted to stop the master cyl getting full travel and the clutch clearing properly, it was fine with the worn clutch because the bite was at the top.
Hi AndyWhy can't the slave be adjusted. If there is a big load of take up before the release bearing reaches the cover then thats wasted movement and could be reduced.
it wont be much, a cut with standard cutting disc will prob be okpedal is flat bar ...i could cut a V and bend it re weld it
done that before in an emergencymaybe hammer a dent in the floor lol
