GW8IZR
Gone.
- Anglesey
you can do this by blowing a tracer down the pipe, I used to find old cat5 cable perfect for this job. very light and slippery to pass down the pipe. Its marked off in metres so you can work out how far it goes etc.
Make a small cone on the far end of the cable then use a co2 bottle or if its practical your compressor to blow the cable along the pipe. Same technique used to blow fibre optic wires down ducts.
Use a signal that you can identify, a good square wave of 900Hz alternating with 950Hz so it warbles then you can tell its your signal. If its clay soil and the pipe is deep then a much lower frequency is better. Send that signal down one of the twisted pairs and at the far end connect the twisted pair to any two random wires (not a pair) then back at the source end connect just one of the wires to the pair of the other.
So lets say:
use a sense coil on a high gain amplifier, bi-mek were very good but I made a copy many years ago for a few quid and a bit of time.
Maplin do sell a kit for about 30 quid but you need to be in a low noise environment such as fields if the cable is deeper than a few inches, but I reckon a bigger coil and tuned to your signal frequency and it would work.
After a few practice goes you will even be able to hear the lay of the cable as it twists
Even if it only goes half way down the pipe it will give you a direction.
HTH
So lets say:
- Signal applied to white/blue blue/white as a pair,
- At the far end connect white/blue to white/orange and blue white to green/white.
- Back at the source connect just white/orange to white/green.
HTH
