the snooper
getting older by the day
- Hull UK
Oi oi oi I'll be round to hammer a piece of wood into that pipe your trying to traceI don't think yours will be big enough
I can stick comp air into it but where do I look for the out put end ??
I've got a big garden
Something not yet mentioned, Get a long length of copper braided co-ax (tv) cable shoved down the pipe and follow it with a metal detector.
I'd chuckle my socks off if someone, in the past, had just shoved a short length of pipe into the ground to confuse a future owner.![]()
and on a more dangerous note, I've seen a few inches of earth wire connected to a shower then just plastered into the wall under the tiles![]()
Wouldn't just sticking a speaker over the end and blasting some noise down there be an option? Granted, some poor sod may think there's a ghost if it leads off into the unknown, but at least an audible tone is generally easy to trace/follow.
Similar thing happened to my mate when he moved into a new house. Connected up the washing machine, his wife filled it & set it going & they went out shopping. Came back to find the ground floor awash. It turned out that the builders had taken the waste pipe out through the wall, but not connected to the drain. Had to have all the units changed due to water damage, the builders tried it on saying they will dry out, but they had all gone too far.The landlord of a pub we were drinking in told us then the previous owner had converted the barn to accommodation, when it rained the rain water down pipe gullies had overflowed so he called out a maintenance guy to clean them out, turns out the gullies were just buried into the ground, no pipe work going anywhere!
The worse thing was the new landlord had just had the car park tarmac'd so it all had to be dug up.
a pair of welding rods dousing sticks u might find it funny but it does work I can do it
I used to work with a guy, now long gone unfortunately, one of our jobs was to track telephone cables & ducts, dowsing was always his first method of choice even though we had a radio scanner & tracer. The only thing was he could not identify what he had found, several times i dug down where he said & found a sewer or water pipe instead. I tried it several times & could not find anything, I could not get any reaction at all.I watched someone do this even though he had a proper electronic scanner in his JCB, he said sometimes he could find pipe runs that the machine wouldn't. I cut a couple of lengths of galvanised fencing wire and found that I could do it too. It's the most bizarre thing, they move as you pass over the pipe. I had previously thought it was a load of tosh.
you never met my Father.....I don't think a metal detector will work as water pipes need to be laid at a depth of between 750mm and 1350mm, that's too deep for a standard metal detector.
Glad we could helpRight you mischevious lot I think the problem s now solved as my kitchen will be shot to pieces by compressed air launched ball bearings, the garden will be flooded by injecting water down the pipe, fire will follow after lithium ball bearings and any veggies will be blown up by air bags, to top it all off all involved parties will be liberally covered in talcum powder
All in all a good productive evenings work
Thank you all so kindly for your assistance
It will be useful to have water far away from the house, pipe is there and poking out of the ground but not installed by me. Just trying to find out and make things easyyou never met my Father.....
his max lay for water pipe was about 100mm....
@Parm
any harm to ask why you want to know where this pipe is going?.
i know tho that we all like to know where pipes are going but times some are a stretch too far.
so much so at the farm here about 3 yrs ago i got a concrete saw and cut the whole yard, i laid 2x 25mm pipes and 2" ducting to every shed here, the yard looks like a map but i have no more leaks, bad plumbing, burst pipes, frozen pipes or anything else for that matter.
a dear job but cheap in the long run.
did you try and blow down it to see if there is a resistance or free air going through it?.
