I posted a while back about leaks in our rather long supply pipe from the water main. The supply pipe is ~1.5 miles from the water main and therefore the main water meter to our property. We think we have fixed all of the leaks.
To try to get a better handle on future problems, we have installed a second water meter as the supply pipe enters our property. The meter by the water main (the one the water company use) is consistently reading 200 litres per day more than the one where the pipe enters our property.
When we discovered this, the first thought was that there was another large leak on the supply pipe. BUT investigations where we have exposed and put stop taps into the supply pipe in various points show that with the water turned off for 6+ hours, next to no use is registered at the meter by the water main. At 200 litres a day difference between the meters you would expect a change of 50 litres over six hours if it was due to a leak. Turning the water off as it enters our property today, the meter moved 6 litres in that time - settling in the long pipe run (?) or a potential small leak (?), but nowhere near 50 litres??
We ran a test this evening and ran 20 litres of water and the meter we installed at our end of the pipe turned and registered 20 litres. So does anyone know - how often do water meters fail and over read?? I believe we can pay to have it tested but I just wondered what the likelihood of a fault was before I went down that route?
