Memmeddu
- Italia Sardegna
Best advice. Don't!
I needed 3x 35mm holes in 12mm steel plate. My rotobroach cutters are 38mm unfortunately. I bought a Starrert hss hole saw with 8% cobalt. Ran it slowly in the Bridgeport. About 200rpm. Used flood coolant. Started well but soon stopped cutting. No chip clearance so needs constant blowing out. After 1 hole it was knackered. Off to Screwfix and bought a Bosch hss cobalt. No arbor with pilot drill. £25 extra. I didn't bother. Held it in an ER32 collet fine. Pilot drill not necessary either.
After 1 hole it also died
@DAPPH said he could fix it. I was rather dubious but fair play 2 minutes with a triangular file and it was as good as new again!
Rotobroach always from now on!
You did something wrong
I've cut 24 consecutive holes on 10mm thick pillars bases (welded in wrong position) using a cheap parkside HSS hole saw and my mag drill.
Yes you have to constantly relieve the cut to break the chips but till you're doing that you'll be fine.
And I've been surprised by the accuracy of the hole, the first 2mm were off because the slack in the dovetails but I've eventually used a piece of 25mm ground induction hardened bar and it fitted snug in the holes.
I didn't use coolant but cutting oil because it sticks better on the tool .
