I'm not sure where you getting things like "brush hammered" from mate , I've never heard that before, I just lay on a light grabber coat and then normal coats 10 mins apart, 2 hrs later you can flat it, this is with Lechlar epoxy, Brushing the first coat on is gonna make any further coats as rough as a bears **** !!!
At the end of the day I don't know of any painter that uses this Jotun stuff which tells me something.
The info on applying the first layer with a brush came from this post by bc30se in this thread
Anyway here are the results (5 x Wellers and 1 x Manx Weller Copy):
Sorry but the only close ups i took were of a couple of areas that may need touching up, like the one below a slight overspray but it shows the finish, the brush stokes are mainly invisible:
