That isn’t an issue for me. I can get a 6” extension in if needed. It does need the shocker to be removed but that’s a 5 minute job. Lots easier than the rear springs, just hope I never have to do that job.If it's anything like my van the issue is the height.
There is part of the axle above the bolt head blocking direct access.
You can get a socket on the bolt but there is not enough room to get a driver into the socket.
So you are left with using a ring spanner, welding a bar to a socket or using a stilson on the socket.
The stilson method works quite well and has gotten me out of trouble before. Sometimes you have to add blobs of weld on the socket to stop the stilson slipping.
