James1979
- Orkney
That’s perfect. CheersThey do normal tape too .. might be a different cartridge to the “normal” machines.
The 300 only goes to 17mm tape
The dymo of mine only does 1/2” or thereabouts anyway.
I have similar for larger stuffAnother option for bundles, big cables etc. is a tie on marker system I've found them useful where I have a load of multicores going through gland plates.
Yes, you get loads of different tapes for them, here you can see clear with white that I added to the side of the LEDs.Just googled them. They’re sub £100 at the moment.
The clincher for me - will it do ‘normal’ tape?
My dymo is knackered and needs replacing so if these will do tube and tapes it’s a no brainer
£20 in three years ain’t bad. Mince pies have gone up more as a percentageJust looked and it was over 3 years ago, got it from Argos for £80.
Good job I hate these ******* things then£20 in three years ain’t bad. Mince pies have gone up more as a percentage![]()
Do they do heatshrink labels for the
Brother P Touch TZ
Ah Ah so mine is no good. I just checked and its a PT 1000.
Ah Ah so mine is no good. I just checked and its a PT 1000.![]()
Oooerrrr that's worth trying I guess. Is that on Amazon?The aftermarket seem to supply heat shrink for the pt1000.
Label Tape Heat Shrink Tube Compatible with Brother P-Touch Label Maker,6mm-24mm | eBay UK
Type: Compatible Brother Heat Shrink Sleeving/Tubing Label Tape. Brother P-Touch Printer Heat shrinkable tube has excellent un-flammability, flexibility, and insulation. The shrinking temperature isvery low and it can shrink very quickly.www.ebay.co.uk
Bob
Specification:
Color: Black on Yellow/White
Width:
- Hse-211 Hse-611 5.8mm (0.23")
- Hse-221 Hse-621 8.8mm (0.34")
- Hse-231 Hse-631 11.7mm (0.46")
- Hse-241 Hse-641 17.7mm (0.69")
- Hse-251 Hse-651 23.6mm (0.92")
Length: 1.5 m
Brother P-Touch Printer:
HSe-211 HSe-611(5.8mm), HSe-221 HSe-621(8.8mm), HSe-231 HSe-631(11.7mm)
★ P-Touch GL-100, PT-1000, PT-1000BM, PT-1010, PT-1010B, PT-1010NB, PT-1010R, PT-1010S, PT-1090, PT-1090BK, PT-1100, PT-1100SB, PT-1100SBVP, PT-1100ST, PT-1120, PT-1130, PT-1160, PT-1170, PT-1170S, PT-1180, PT-1190, PT-11Q, PT-1200, PT-1230PC, PT-1280, PT-1280SR, PT-1280VP, PT-128AF, PT-1290, PT-1290BT,PT-1290BT2, PT-1290RS, PT-1300, PT-1400, PT-1500, PT-1500PC, PT-1600, PT-1650, PT-1700, PT-1750, PT-1760, PT-1800, PT-1810, PT-1830, PT-1830C, PT-1830SC, T-1830VP, PT-1880, PT-1880C, PT-1880SC, PT-1880W, PT-18R, PT-18RKT, PT-1900, PT-1910, PT-1950, PT-1960, PT-200, PT-2030, PT-2030AD, PT-2030VP,PT-2100, PT-2110, PT-2200, PT-2210, PT-2300, PT-2310, PT-2400, PT-2410, PT-2430PC, PT-2470, PT-2500PC, PT-2600, PT-2610, PT-2700, PT-2710, PT-2730, PT-2730VP, PT-300, PT-300B, PT-310, PT-310B, PT-320, PT-330, PT-340, PT-350, PT-3600, PT-520, PT-530, PT-540, PT-550, PT-580C, PT-6100, PT-7100, PT-7500,PT-7600, PT-9200PC, PT-9200DX, PT-9400, PT-9500PC, PT-9600, PT-9700PC, PT-9800PCN, PT-D400, PT-D450, PT-D600, PT-E200, PT-E300, PT-E500, PT-E550W, PT-H300, PT-H300LI, PT-H500LI, PT-P700, PT-P750W, ST-1150, ST-1150DX, ST-5
HSe-241 HSe-641(17.7mm)
★ P-Touch PT-1300, PT-1400, PT-1500, PT-1500PC, PT-1600, PT-1650, PT-170, PT-1700, PT-170K, PT-1750, PT-1760, PT-1800, PT-1810, PT-1830, PT-1830C, PT-1830SC, PT-1830VP, PT-1880, PT-1880C, PT-1880SC, PT-1880W,PT-18R, PT-18RKT, PT-1900, PT-1910, PT-1950, PT-1960, PT-2030, PT-2030AD, PT-2030VP, PT-2100, PT-2110, PT-2200, PT-2210, PT-2300, PT-2310, PT-2400, PT-2410, PT-2430PC, PT-2470, PT-2500PC, PT-2600, PT-2610,PT-2700, PT-2710, PT-2730, PT-2730VP, PT-300, PT-300B, PT-310, PT-310B, PT-320, PT-330, PT-340, PT-350, PT-3600, PT-520, PT-530, PT-540, PT-550, PT-580C, PT-7500, PT-7600, PT-9200DX, PT-9200PC, PT-9400,9500PC, PT-9600, PT-9700PC, PT-9800PCN, PT-D400, PT-D450, PT-D600, PT-E300, PT-E500, PT-E550W, PT-H300, PT-H300LI, PT-H500LI, PT-P700, PT-P750W, ST-1150, ST-1150DX, ST-5
HSe-251 HSe-651(23.6mm)
★ P-Touch PT330, PT350, PT520, PT540, PT580c, PT1400, PT1500pc, PT1600, PT1650, PT2200, PT2210, PT2300, PT2310, PT2400, PT2410, PT2430PC, PT2500pc, PT2600, PT2610, PT2700, PT2710, PT2730, PT2730VP, PT7500, PT7600,PT-H500,PT-E500, PT-D600, PT530, PT550, PT3600, PT9200pc, PT9200dx, PT9400, PT9500pc, PT9600, PT9700PC, PT9800PCN
Is it acceptable to add a Tool and then try and find a use for it after it arrives I wonder ?
You know how people say there are no stupid questions?Is it acceptable to add a Tool and then try and find a use for it after it arrives I wonder ?
I misread your post and thought it said they DO do heatshrink tapes for the P touch TZ. So I went on Ebay to look.Do they do heatshrink labels for the
Brother P Touch TZ
