Toscane
Material: 3.0 mm sheet metal
Rods: Oerlikon Overcord S 2.5 mm E6013
Setup: Inverter, clamp (-), electrode (+), ~60A
Joint: Butt
When I lay a pretty decent bead, everything seems fine; it's clean, slug erection occurs, very little splatter and nice looking bead. When I lower the amp, it becomes too tall and when I pump it up, it goes too shallow.
The problem rises when this thing starts cooling down... I hear this very tight popping sound, it's pretty high pitched but has some bass to it too but not enough low frequency to make it deep; it's loud and scary though.
Then I find this longitudinal crack going right in the middle of the bead, it's a perfect crack, it's dead centred inside the bead.
I turned the dial higher to penetrate the metal more and when it was cooling, I heard the same sound but there was no crack on the bead then I started grinding it flush to the metal and then it appeared once again. It was sitting under the bead.
I'm adding pictures of the bead before grinding process and after.
There is also this picture, it's just for reference, came from Google:
Joint: Butt
