Oil and heated rod:
A steadier hand than the guy in the video, gives a neater "cut"
What's the purpose of the water, looks like he only dips the rod into the oil?Oil and heated rod:
And was an indexable end mill the only metal bar he could find?![]()
I couldn't get this to work with my hammer drillIf you need to drill a hole in the bottle to make a lamp, you can drill glass with a masonry drill using a hand drill. Use very little pressure & a bit of white spirit to lubricate, just take it gently. I know you can buy proper glass drills, but most of us have a masonry drill about. ........ don’t try & centre punch it though![]()
Does any one know what the little wheel on the tip of a glass cutter is made off?
Not sure which you have, but the TOYO glass cutters are defiantly made from carbide.
Description from these guys shows: https://ecohold.co.uk/product/toyo-tc20-glass-cutter/
How did the lamp turn out?
I haven’t found a way to do this at home
What about a carborundum stone?Hi John, they came out great.Both taken by my brother
One thing I’ve learned is that is very difficult to make safe the cut edges. I haven’t found a way to do this at home
DohJust noted, this is over a year old
