I did some training in regulator inspection & service, back in the days before the inspect replace rules came in. We were told never to try to repair the internals of a reg, that was strictly only for the manufacturers service department. All we could do is replace a damaged stem, nut or pressure gauge.
BUT if the safety flap in the gauge blew out, like in this case, that meant a drastic internal failure had occurred in the reg and that rendered it junk as the repair cost would be more than a new unit.
Like you I would have a go at repairing most things but if the regulator has failed the way you suggest UNDER NO CIRCUMSTANCES try to repair it - the consequences if you get it wrong are not worth thinking about.
I would suggest you go onto youtube & watch a few videos of what happens when the valves break off gas cylinders or the regs fail. That might change your mind!
. So many don't have a clue what it is even, let alone it's use and what it actually does. Anyway, having that gauge sourced and hope I can get one. I like that regulator.
