Hi I'm am after some help regarding my mig welder, I have noticed a leak from where the torch line comes out from the main unit , it is a Clarke 140e mk2 and I assume that I have damaged the pipe after years of wrapping the hose around the machine, I have removed the line from the welder , to see if I could repair it but I am no sure where the gas goes ! Does it run down the liner with the wire ? It has a metal liner with a plastic cover and the cover has come away from near where the leak is coming from . So could I just replace the liner assuming the gas runs through it or do I need to replace the whole torch , if so should I go for a euro conversion kit or just refit the same fixed type
Thanks in advance
Paul
Thanks in advance
Paul
