the snooper
getting older by the day
- Hull UK
Exactly what I usePlug in power meter will give you volts/hz/watts, very handy for checking generators.
Do you have a multimeter? Does it have a frequency (Hertz) measuring capability?
If you measure the frequency, you know the motor rpm too (I believe).
have you,good gimme it pleaseeeeeeExactly what I use
Got mine from maplin years ago for a tenner, you can plug stuff into them and they will show exactly what power has been used over the time period shown on the clock so have a few good uses especially setting speed on a generator and alike and if your genny doesn't show it, it will show you what the load isErm no mine hasn't
Could you enlighten me on what type,make model etc
have you,good gimme it pleaseeeeee![]()
In the midst of ordering one actually,thanks for that tip,just how much of that reflective tape do you get,and can you buy more if it runs out?
Further more,seem the 240 genny side works
Now thats the main test it boils the kettle
Also ran an grinder and a 1200w hoover both under load so happy there,haven't got any 110v tools but i'll borrow something from someone.
Main this is to sort out the welding side of things,think i'll go with adaptor plugs easy for me and saves hassle![]()
