hotponyshoes
- Somerset. Uk
Ignoring losses, to weld at 100 Amps with 50v OCV for 1 hour you would need 5 KWh, which is about a sixth of the battery in a Nissan Leaf.
A good Li-Ion battery can hold 200 Wh per Kg, so the battery would weigh a minimum of 25 Kg.
An hour of constant welding is a lot, 30mins from a 12.5kg pack would be good.
That's an hour if you carry one pack in each hand across a field with the sub 10kg welder on a backpack.
The BMS better be done right too, if you've seen the damage a vape does when their single 18650 cell explodes, you won't wanna be anywhere near this thing unless you know its perfect.
