Changing rear Discs on a Transit.Easy I have heard people say well this is my experience. Looked at the you Tube Vids plus reading People method. My Transit is a Mk7 2008 SWB Rear Wheel Drive low roof 2.2. Decided to change the rear Discs and Pads. Wheel off remove brake pads,Carrier,Caliper, Now this centre Hub Nut must be the tightest Nut I have ever come across. Got the Air Ratchet out and it would not budge the Nut,A bit better luck with Machine Mart 240v Electric Ratchet Gun. Not a Lot,Then I got my Long Breaker Bar out still very difficult to move the Nut, Now I got a 10 foot Scaffold Pole over the 2 foot long Breaker bar Then slowly one flat of the Nut at a time I removed the Nut.... only problem now after checking and checking for anything holding the Hub on the Stub Axle but all clear Except the B%%%% HUB wont come off, Later today I'm going to try a Hub Puller see if that will move it.. Easy I was Told. Good Job I'm retired and my Transit is not my main mode of Transport. Any Ideas ?
and if you ask it's cause i work in fleet and maintain the same vans year in year out. It'll be fine
