I recently bought a single phase Fobco Star Pillar drill.It had been working great with no play in the quill at all,however whilst using it tonight the chuck fell off
After close inspection the screw that holds the chuck on is missing and the remains of the screw are snapped up inside the shaft. Im after some advice please gents. what would be the best way to remove the remains of the screw and would anyone know what thread and size the screw would have been ? Or could anyone advise me if I could take it anywhere to be fixed. Im sure parts can still be bought for these machines but the problem will be to get the broken screw out.Thanks for any replys.
ps it is fitted with a no6 taper Jacobs chuck.
After close inspection the screw that holds the chuck on is missing and the remains of the screw are snapped up inside the shaft. Im after some advice please gents. what would be the best way to remove the remains of the screw and would anyone know what thread and size the screw would have been ? Or could anyone advise me if I could take it anywhere to be fixed. Im sure parts can still be bought for these machines but the problem will be to get the broken screw out.Thanks for any replys.ps it is fitted with a no6 taper Jacobs chuck.
When I looked at it there is a screw broken about 5mm up inside the shaft. No photos as I needed to be using it again asap so I took the easy route and put a dab of Locktite in the chuck then put it on the shaft and using a small bottle jack gave it a little push up the shaft (very gentle).I know its a bodge but I will get round to fixing it properly when I dont need to use it as much. (busy making bunk beds ) Thanks again.
