Wallace
- Staines, Middlesex, England.
Looks like a wheel rim with a section welded on.I wonder what the cutting 'drum' is made from. Big Gas bottle?![]()
What sort of reduction box would that be?This should put peoples health and safety fears into perspective. Anyone fancy making one?
It's worked faultlessly from beginning to end and I can't emphasise enough just how much bending and backache it has saved. Now the wood is done I can now take it apart add the finishing touches and give it a paint job.I meant like how it is in this video, theres more time to feed before cutting beginsIt needs the ramp up to cut more easily and require less power to cut - also stops (or reduces) any shock loading on the pto.
heres a closer view of it
an electric version of above
this one goes into the front it also splits the wood as well
I meant circumference, not radius, but i bet you got the idea what i meantThe things i would change-
I wouldnt have the guillotine around the full radius of the rim, to give more opening time to feed the wood before the start of the cut.
