I`ve begun fabricating a dropped, towing hitch-plate for my nephew`s modified Land Rover 90.
Using my Quasi-Arc: 3.2 mm./6013`s at 60 Volts/124 Amps. (single pass)
When making one of the fillet runs; `twixt the 13 mm. back-plate and the 5 mm. sides, I noticed a small hole appeared near one edge of the fillet (see pic).....I`m thinking it was a momentary-change in rod position that caused it; but, perhaps it is from some other cause? (contamination etc.)
......should I grind it out and re-do the run?
