Okay that sounds brilliant , I will have a good look at those three and see which one takes my fancy.If you get it just right, you can more or less push the rod into the joint with steady pressure. The arc burns up inside the flux and everything runs nice.
That first one looks good. But only cut and etch will tell you if you've got full penetration.
There are a lot of decent stick welding inverters out there these days. Even midrange ones are pretty darn good.
For the best.... (and it's just opinion)
These below are the inverters, that to me, are at the top end of small stick welding. They all behave like a much bigger machine. They make stick welding sooo easy. They're all rolls royce machines. There are others, but these are the ones I've tried.
Minarc Evo 180 180A 230V 61002180
KEMPPI MINARC EVO 180 180A 230V 61002180 All MMA Packages include MMA Lead, Earth Lead, 5.0Kg Pkt 6013 Electrodes, Wire Brush, Chipping Hammer, Welders H/Duty Gauntlets, French Chalk & Holder.230V 16Amp Plug fitted with 13Amp Adaptor Lead, (415V 16/32Amp, 4/5Pin) 3 Year Warranty Pre-Registered...www.brooksideweldingsupplies.co.ukIgnis 150A MMA Stick Welder Package With Lead Set
The Fronius Ignis 150A MMA Welder from TEC Products. Buy today and receive FREE standard shipping on orders over £100*www.tecproducts.co.uk
New Lorch Micor 160 accuready Inverter Arc welder with optional rechargeable battery pack available at wasp supplies ltd
Lorch Micor 160 amp Inverter Arc welder with lift tig function that can be powered by a rechargeable battery, a generator or 240 volt mains power. 21 electrodes of 2.5mm diameter can be welded when powered by the Mobilepower1 battery pack. buy online from wasp supplies ltd.www.waspsupplies.com
Of these three, I'd take the Fronius or Lorch.
Of those two, I'd buy the Lorch, all day every day.
