Brad93
- Essex, United Kingdom
As per @Munkuls suggestion, i would also happily use any of those three machines.If you get it just right, you can more or less push the rod into the joint with steady pressure. The arc burns up inside the flux and everything runs nice.
That first one looks good. But only cut and etch will tell you if you've got full penetration.
These are the inverters I have first hand experience of, I've tried lots of welders but these 3 are to me, are at the top end of small stick welding. They all behave like a much bigger machine. They make stick welding sooo easy.
Kemppi Minarc Evo 180 230V, 180A
Kemppi Minarc Evo 180 MMA Arc Welder, 230V Including Arc Cable, Earth Cable & Shoulder Strap Package Includes: 3 Metre Weld,Earth Lead & Shoulder Strap. FOC Spares: 5kg mild steel electrodes, wire brush, chipping hammer, welders gauntlets, french chalk & holder SEE PHOTO also with 16amp 230v...www.brooksideweldingsupplies.co.ukIgnis 150A MMA Stick Welder Package With Lead Set
The Fronius Ignis 150A MMA Welder from TEC Products. Buy today and receive FREE standard shipping on orders over £100*www.tecproducts.co.ukNew Lorch Micor 160 accuready Inverter Arc welder with optional rechargeable battery pack available at wasp supplies ltd
Lorch Micor 160 amp Inverter Arc welder with lift tig function that can be powered by a rechargeable battery, a generator or 240 volt mains power. 21 electrodes of 2.5mm diameter can be welded when powered by the Mobilepower1 battery pack. buy online from wasp supplies ltd.www.waspsupplies.com
Of these three, I'd take the Fronius or Lorch.
Of those two, I'd buy the Lorch, all day every day.
I would probably pick the lorch, given that i have had the micorstick for 6 years and it's been fantastic.
