must be incredible stuff if it can loosen an aluminium brake caliper when the slider pin is siezed in and it wont even loosen with a lot of heat and had to be drilled out in stagesNever had any success with Plusgas even left overnight, same with GT85 which I can get cheap.
Where above fail to release one spurt of LT8, leave for 30 secs and just undo job done.
There was a thread on this last year approx £8 a can.
Where you can feel nuts twisting the bolts as in shearing, one spurt of LT8 has freed off, that's the difference.
must be incredible stuff if it can loosen an aluminium brake caliper when the slider pin is siezed in and it wont even loosen with a lot of heat and had to be drilled out in stages![]()
