arther dailey
- England
heat fan boss with oxy/acet torch, keeping away from shaft, lever of, when refitting use loctite bearing fit.
Be very careful using emery in the lathe
http://www.hse.gov.uk/engineering/lathes.htm
I cover the bed up and carriage so that it doesn't get on the machine
Don't forget your untucked tie!I always make sure to wrap the ends around my fingers and wear loose, baggy clothing when sanding on the lathe
You need a watch and lots of bling.
