arther dailey
- England
heat fan boss with oxy/acet torch, keeping away from shaft, lever of, when refitting use loctite bearing fit.
Be very careful using emery in the lathe
http://www.hse.gov.uk/engineering/lathes.htm
Don't forget your untucked tie!I always make sure to wrap the ends around my fingers and wear loose, baggy clothing when sanding on the lathe
You need a watch and lots of bling.
