They seem to be a good machine and can take a bit of use and abuse, unlike most if the far-eastern rubbish. Does the no.1 have a morse taper in the spindle ?
OY what you doing poaching my bargains. lol
I'm pretty sure it does, but I couldn't tell you what size. Mine is steadfastly resolute in its stubbornness to move and as I've never needed it, I thought it best to let sleeping dogs lie. I think you need wedges to remove them.
Thats ok then. lol I just cant find a decent drill with a morse taper anywhere local.I'm sorry. It was a while ago. lol
I think he probably means a drift when he says wedges.You don't really, a simple drift should be enough to shift it.
are you taking the p** or not reading the question correctly ? we have followed all the numbers on drawing... But at the bottom of the drawing it says .. one lead from capacitor must be taken direct to switch.. .............. it dont say what number on switch to attach the wire and dont say what wire from capacitor...Just follow tge numbers on the drawing, assumin thatcyou are using tge original Krater switch.
.. and this was already answered in the other thread.are you taking the p** or not reading the question correctly ? we have followed all the numbers on drawing... But at the bottom of the drawing it says .. one lead from capacitor must be taken direct to switch.. .............. it dont say what number on switch to attach the wire and dont say what wire from capacitor...
If you look at the drawing it shows you. I'll leave it at thatare you taking the p** or not reading the question correctly ? we have followed all the numbers on drawing... But at the bottom of the drawing it says .. one lead from capacitor must be taken direct to switch.. .............. it dont say what number on switch to attach the wire and dont say what wire from capacitor...
A1 to No. 3 : correcton this diagram all wires connect as per the diagram.. but at the bottom is says... one lead from capcitor must taken direct to switch ? what lead does it mean > where on capacitor and where to on the switch.... when wired like it shows on diagram it just buzzes..... i put A1 TO NUMBER 3 ........... Z1 to number 6,.......... Z2 to number 5 .....A1 to number 7... all i get is the motor buzzing. i have no clue as t owhat it means by a wire direct to switch from capacitor. its this last wire i cannot understand where from and to ?
...it is the symbol to the right of the centre, with two short horizontal lines separated by a gap..
