metalspanner
use a mk 4 fen trap with chocolate on itit sorts grey squirrels out as well if u put it in a large pipe or a box with open ends
or if not under a building find the hole and flood it with propane then add some oxygen
plug the hole with some wire wool atatch leads stand back conect to battery and watch the ground lift
next trick drop a ferret in the hole bolt them out stand back with shotgun and a terrier . make sport out of it as well
Sounds a bit like the rodenator, the ONLY drawback with this brilliant plan, is our liberal laws, the rspca say you MUST ensure all animals are OUT of the burrow before using this method.
I thought the whole idea was to kill the bloody pests, not disperse them over an even bigger area
