gordon stephenson
- Skelton in Cleveland U.K.
But welding cable is multi stranded fine copper with a thin tin coating, Unless the tin could effect the process, Nothing that could rust involved.
Power supply 12-24v 4-5 ampsCan anyone link to a power supply and the acid required for this process. Got a few stainless jobs coming up and this is so much better than picking paste!
Solution is described in my first post.
Positive terminal on the job
Negative terminal on the brush
The Fixed voltage is way too high in stick mode. You don’t need anything more than 12-24 volts and single digit amps. AI passivated my stainless welding cart last night - tried 3 machines using turbo easykleen fluid and a carbon brush holder in a stick electrode holder.
1. Miller XMT - had to use the stick setting since it didn't have an electrode-hot mode in TIG. Min amps 6a. Wayyy too much voltage - violent explosions.
2. Lorch HT200 - stick setting - min amps 10a. Also got explosions etc until I changed the hot start and arc force settings. Worked pretty well after that.
3. Jasic Arc 160 - min amps 10a. Auto hotstart/arc force, too powerful but did work.
- Switched the Jasic to lift-TIG mode and it then worked really well, as well as the isojet 5 that cost £1000 at work![]()
I honestly don’t know. Your probably right it might be the same and it might be fine.Would a tig welder see this as a dead short though?
If the brush is wet (and presumably carbon has some resistance) and the cleaning action must use some current it cant be any different to tigging at 5amps can it?
The copper part of the brush touching would be a dead short but no different to touching down with a tungsten although a tungsten may have much higher resistance than copper.
Some tigs have an anti-stick feature which cuts power if this happens so might be ok?
Not something I would try with any of my welders I hasten to add!
We also have an old IFL TIG set that we intend to dedicate to the job if it can be repaired.And it won’t because your only pulling minimum current!Even using the Lorch on stick mode, the fan didn't spin up all that much,
Fronius did it years ago with the mark 1 magicwave 2000. They had an extra option you could add to the machine called magic clean. It included a remote control, a wand and some solution. I’m guessing it wasn’t a great success as they didn’t carry it on with later models, they built a dedicated machine.yeah, that's a fair comment
I wonder if some of these unknowns are reasons why passivation companies are reluctant to say "look, you can use your expensive TIG welder as a perfectly good power source!"
Anyways yes, I won't use the Lorch any more![]()
