Tinbasherdan
Bodger in chief
- Bolton, England
Unfortunately the 621 is a domed piston not a flat top, those kits don’t work too wellPardon our interruption...
www.ebay.co.uk
www.ebay.co.uk
Just a shame I can’t get a new piston for it to freshen it up again![]()
It’s not in the rudest of healthIf the piston is not scored you only need new rings and only then if the compression is low.
Oooh! Tell us more!
The Mericun’s are big into faster chain speeds and frigging with sprocket diameters, the only problem is chain length and remembering that chain length reference stamped on the bar could be wrong.
Bob
A firewood saw doesn't really need to be any bigger than 50cc.but for cutting firewood they are a bit over the top.
I'll just reiterate what our training instructer said when I started my apprenticeship " These machines , lads, are designed to cut metal ( insert 'trees' here) , they cut meat even better."I'll echo what everyone else says - they are dangerous things and not toys.
Buy a decent hand saw or an axe...
IF you must have one just for this job electric is the way to go (meaning mains not cordless - spend the difference on PPE)
If you put a rough location in your profile you might even have got an offer of assistance / tuition![]()
Perfectly true. I having a lot of trees. Estimated at 500 or so. I gave up the petrol one's as when they're laid up over winter don't seem to want to start. My Makita is fine. Most accidents I believe (could be wrong and often am) are people using whilst climbing trees or working of ladders. At ground level with proper care and sensible footwear and gear they're not an issue. For lopping branches I use my chained lopper. Almost impossible to injury oneself with that and you CAN legal hire one.how many do you have to do? one, or two not worth dicking about spending out..... if you have a load to do aye maybe, but if it's just one or two, 8" diameter is well within the realms of a hand saw.. or if you want to use the recip, just cut it from both sides, in wedges, then cut through finally. Axe, isn't that difficult either.
Avoid chainsaws if you can, especially if you've never used one, and probably have no great need later. There's nothing particular onerous about them, you just need to know the safety sides of things, always have a healthy respect for what damage they can do, and plan ahead with lots of common sense, but if you can avoid them all the better. The saw proposed by james would be through it before you have a chainsaw fueled, sharpened and oiled...
Most chainsaw accidents I’ve seen/heard about have been on the ground. A mixture of trained and untrained operators. Trained ones being overly confident and the untrained ones, just that untrained.
Had a look at the statistics on an HSE site and the details are a big difficult to quantify. Few fatalities, most injuries to upper body (no surprise there) and caused by falling branches or kick-back and pull-in. So yes that means at any elevation. My saw is only 10" and tends to stall if jammed. Had chain come off guide lots of times when jammed. However some of the larger saws would be lethal when your talking 24" and up. One other thing is risk levels change when a 2nd person is involved. A 'helper' can often be the opposite. My trees are from bush size to >30ft 12" dia +. But a 10 inch saw used carefully can cope.Most chainsaw accidents I’ve seen/heard about have been on the ground. A mixture of trained and untrained operators. Trained ones being overly confident and the untrained ones, just that untrained.
Be interesting to know how many of those injured were professionals vs diy market. It’ll be a bit skewed as there’s pros and people who are paid to do it. Also, a lot of people who work in that environment don’t run to hospital with every scratch so it won’t be an accurate reflection but interesting none the less.Had a look at the statistics on an HSE site and the details are a big difficult to quantify. Few fatalities, most injuries to upper body (no surprise there) and caused by falling branches or kick-back and pull-in. So yes that means at any elevation. My saw is only 10" and tends to stall if jammed. Had chain come off guide lots of times when jammed. However some of the larger saws would be lethal when your talking 24" and up. One other thing is risk levels change when a 2nd person is involved. A 'helper' can often be the opposite. My trees are from bush size to >30ft 12" dia +. But a 10 inch saw used carefully can cope.
As for bar size. A bar will do a tree of 2 1/2 times bar length if you know what you’re doing with it
Brown ones.Blimey, my knob is at risk, I'm off to buy some chainsaw trousers.![]()
