E36 random work
  1. TwoThumbs
    TwoThumbs Member
    121
    Finland
    Took few pictures of the improvements and repairs done for E36.
    Subframe bush looking crusty:
    DSC_4324.jpg Rear anti roll bar mounting point reinforcement from 3mm flat steel:
    M3 reinforcement plates welded to the chassis mounting points and brushed first coat of epoxy:
    Subframe bushing puller made from some rod, large socket, 3" exhaust pipe and flat steel:
    ewmIreland, Bear and slim_boy_fat like this.
  2. TwoThumbs
    TwoThumbs Member
    121
    Finland
    E36 sitting in a shed and this time dealing with boot lid rust issues. Trim mounting holes and lower corner showing paint bubbles plus inner seam sealing was compromised allowing moisture to travel under paint.
    Turns out fix was easier than I expected and metal was still in fairly good condition so less complicated body filler solution was used.
    DSC_4389_e36_trunk_lid_rust.jpg DSC_4393_e36_trunk_lid_rust.jpg DSC_4395_e36_trunk_seam_rust.jpg
    Didn't take pictures in middle stages but it went approximately...
    Peeled damaged seam sealant and wire wheeled folded edge, ground rust spots away and used skim goat of fiberglass and standard body filler, painted with epoxy primer and renewed seam sealer best I could.
    Lid after painting:
    Will allow it to cure completely before colour sanding and buffing process, final colour might never match 100% on a red car but I think it will look better now without rust spots.
    eLuSiVeMiTe, slim_boy_fat and MarkMc like this.
  3. TwoThumbs
    TwoThumbs Member
    121
    Finland
    This time fixing badly rusted front anti-roll bar mounting points, definitely another e36 weak point found.
    New mounts from BMW dealer were reasonably priced:
    Open seam between mount and frame rail allows dirt and water to fill the thing, recipe for rusting so it needs some additional seam sealing.
    Finished result. Painted with epoxy, seam sealed all a way around, sprayed with anti-stone chip and insides protected with Dinitrol Ml.
    Cheers till next time!
    jpmillermatic likes this.
  4. SIP-Free
    SIP-Free Member
    991
    Dan Saff!
    Can you explain, "..... used skim coat of fiberglass and standard body filler..." a little bit more? I've not heard of this before.
  5. TwoThumbs
    TwoThumbs Member
    121
    Finland
    Sure, skim coat = very thin coat of filler and products were fiberglass reinforced body filler and "standard body filler" was my normal polyester body filler. Intention was to use fiberglass filler first to seal any potential pinholes (I don't think there were any but extra insurance taken) and add a water resistant layer between metal and top coatings. Normal body filler was used to smooth out rather coarse fiberglass filler and it's easier to get it sanded for paint ready stage.
  6. Miggy89
    Miggy89 Member
    129
    Somerset uk
    some good looking work there keep us updated
  7. Jim Davey
    Jim Davey R H Davey Welding Supplies Ltd
    5,366
    Southampton
    Nice, I do like a good 3 series. Definitely a bucket list car for me.
  8. TwoThumbs
    TwoThumbs Member
    121
    Finland
    Hi. I have been again working with my E36.
    First couple older pictures from the stock pile:
    Fabricated reinforcement plates to the rear trailing arm mounting points from 3 mm steel:
    Got a BMW limited slip differential:
    More recent pictures.
    Already patched small rust hole from rear wheel well where mounting stud for fuel neck would mount:
    Trunk floor had some surface rust that was wire brushed with air tools, treated with rust converter, painted with 2k epoxy primer and painted to color:
    Will continue to the next post...
  9. TwoThumbs
    TwoThumbs Member
    121
    Finland
    Rust has been growing where eyes can't see, behind sill covers where rear jacking point is located:
    Inner structure of the jacking point was still strong metal, it got wire wheeled and treated with rust converter before patching the hole:
    Fabricated patch panel with some holes for plug welding to the inner structure, inside of panel was painted with etch primer and weld thru primer in areas where welds would go:
    Welded it up:
    Painted with epoxy, hollowed with bit of body filler and finished with another coat of epoxy:
    Painted it up and inside was coated with Dinitrol ML cavity wax:
    jpmillermatic and lazybones51 like this.
  10. TwoThumbs
    TwoThumbs Member
    121
    Finland
    Some time ago it came to my knowledge that boot lid on E36 had a tendency to develop cracks where latch will bolt and if it get bad enough latch itself may brake.
    Sure enough cracks were developing also on my car:
    Cracks were stop drilled with 2 mm drill bit and made slight groove to improve weld penetration with dremel and some tiny cutting disc:
    Welded:
    Ground smooth, carbide deburr was used to shape bolt holes:
    Repair was sprayed with epoxy but rest of it is still in making. Unfortunately I will have to revisit my boot lid paint job that i did 2 years ago. Rust has been continue it's forming under the body filler causing minor paint bubbles. Will try slightly different method for painting this time (rust converter, epoxy and if it needs filler it will be done on top of epoxy and everything will be sealed with epoxy again before final color).
    aguycalledsteve, hunter27 and Dcal like this.
  11. aguycalledsteve
    aguycalledsteve Member
    488
    Mansfield
    I can't help but see faces in these pictures. My Pareidolia must be playing up again.
    Good work on the repairs though, I like reading threads like this. Inspiring.
  12. slim_boy_fat
    slim_boy_fat Forum Supporter
    You've been a busy boy, keep up the good work :thumbup:
  13. wookie Member
    2,597
    Do it, I had a e36 years ago, it was a great car. Was comfortable munching the motorway miles and then a blast to drive on the twisty bits, very sure footed but equally you could be a hooligan and get the rear out if you wanted. The biggest problem with mine was it ate front suspension bits for fun (they are known for it) but then I did give it a hard time :D
  14. TwoThumbs
    TwoThumbs Member
    121
    Finland
    Another set of pictures coming up.
    Boot lid got paint:
    Now working with doors that had some rust spots from stone chips:
    Treated with rust converter and primed with coat of epoxy:
    jpmillermatic and slim_boy_fat like this.
  15. 130 Member
    668
    UK North West
    Well done, I have two E36 Coupes and the level of body rot definitely has gone up exponentially since they passed 20 years old
    slim_boy_fat likes this.
  16. slim_boy_fat
    Alive & well, or projects?
  17. 130 Member
    668
    UK North West
    328 is daily drive since 2009 and 325 is wife's daily since 2010 (cost £600)
  18. TwoThumbs
    TwoThumbs Member
    121
    Finland
    More door pictures as they got done finally.
    Doors were removed to give better access to the insides and front edges:
    Rust has gone under the seam sealer at the front doors and traveled further than it looks:
    Affected seam sealer removed for treatment:
    There is possibly few ways how to replicate outlook of factory seamsealer if facing this issue. There may be products that are easier to match or can be sanded to match when cured. Another option is to form a tool from wood, plastic may work too and smooth out the sealer to match after it's applied. Then there is a way where old sealant got cut with sharp blade and "glued" to the top of thinner layer of new sealant.
    I settled to make a tool from wood and using soapy water it turned out acceptable for a driver but next time I will spray the sealer with wax and grease remover to make it even slicker and easier to form than what the water did.
    Never the less after priming them doors around ten times they got some red paint and color sanding / polishing for final result:
    Doors were quite lot of work, that's one for the 2 door car's for sure.
    Then to the front end....
  19. TwoThumbs
    TwoThumbs Member
    121
    Finland
    Pulled some of the front end to pieces.
    Front fenders had some rust ended needing some small patches welded to the wheel sides:
    Front clip primed:
    Fenders primed:
    New paint sprayed:
    Fenders were hanged for painting:
    That's all for now. Cheers and thanks!
  20. TwoThumbs
    TwoThumbs Member
    121
    Finland
    Did quick scuff and shoot for sill covers while they were still removed:
    Next some my favorite work with chassis reinforcement. Went and pulled front subframe:
    Made doubling plates from 2 mm steel for engine mount bolt holes:
    And 3 mm outer boxing plates, corners left open to improve water draining:
Advertisements
