I've had that Sino display for four or five years supplied by M-DRO. Recently a column stopped working but was able to fix it quite easily. (There's a post about it on the forum).We're looking to fit 3 axis dro to our Sieg SX3 benchtop mill. I've been looking on ebay and see kits that would suit at about £250 supplied from the UK, and £200 direct from China. And this SINO one is £168 from China:
I'm drawn to the ones supplied in the UK as it'd be easier to return if it doesn't work. But apart from that, is there any difference in quality between the different kit advertised on ebay in that price range? Or are they all coming from the same factory? I've read all the posts I can find on here relating to DRO and I see one or two people referring positively to Sino, but it's all a bit of a mystery to me.
Any comments or recommendations gratefully received!
Thanks, Chris
I bought most of my recent lathe Dro via AliExpress and have had no problems. I ordered as separates just incase there was a problem and I had to send something back, The packaging did leave something to be desired, but they all arrived without any damage so it was fit for purpose. I had to make the brackets and magnetic scale covers but the cost was less than any three axis I could have purchased elsewhere.Thanks Richard.
The lengths are 150, 300 and 400mm.
I was thinking maybe the Aliexpress one I linked to above and then scales that fit, but tbh I'm inclined to go with the ebay one I linked to earlier in the thread
At least they're going to fit if I get them from that same source (my knowledge of electronics extends to changing a light bulb), and tbh I'm not too impressed by Aliexpress's rating on Trustpilot, and don't really want the hassle if things go wrong. I'm sure MDRO would be even easier but that's £££ in comparison.
You can cut them down to size if you need to.Is the key term (in this case) TTL - if both readout and scale have that, they should fit? Sorry to be slow, your earlier post should really make this clear to me I guess!
So, for eg, this:
and this:![]()
SNS-3V SNS-2V Dro 2 3 Axis Digital Readout Display TTL Signal 80V to 250V for Lathe Milling CNC Boring Machines - AliExpress 1420
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
should fit together?![]()
2 3 Axis DRO Digital Readout Display 5μm TTL Linear Scale CNC Mill Lathe Machine | eBay UK
2/3Axis Digital Readout DRO LCD TTL Glass Linear Scale Encoder CNC Milling Lathe. Digital Readout& Linear Scale. 1pc Digital Readout only or 1pc linear scale only (Travel Length 100mm,150mm,200mm. 1500mm for choose).www.ebay.co.uk
The ebay sites seem to have the lengths I want, but not the Aliexpress site.
I have fitted a DRO to my Colchester Triumph. Sadly I have not been that impressed. Essential on a milling machine but less so on a lathe. I find the dials are more than good enough. I only tend to use it for travel along the bed - perhaps I should have bought a trav a dial insteadI bought most of my recent lathe Dro via AliExpress and have had no problems. I ordered as separates just incase there was a problem and I had to send something back, The packaging did leave something to be desired, but they all arrived without any damage so it was fit for purpose. I had to make the brackets and magnetic scale covers but the cost was less than any three axis I could have purchased elsewhere.
I understand your qualms, the ToAuto is cheapest, but they don't mention scale physical size, which is something you should check on before ordering.
The Sino one JMS linked to allows you to pick which size scale as well as length.
I use my Lathe DRO all the time, have you got it set to read diameter? Wouldn't be without it.I have fitted a DRO to my Colchester Triumph. Sadly I have not been that impressed. Essential on a milling machine but less so on a lathe. I find the dials are more than good enough. I only tend to use it for travel along the bed - perhaps I should have bought a trav a dial instead![]()
Yes I have but found it easier with the dials. If I am using mm though I use the dro. I suppose it depends on how good the dials are.I use my Lathe DRO all the time, have you got it set to read diameter? Wouldn't be without it.
Robert - in retrospect, did you need the slim scales? I'm looking at ours and there seems to be plenty of space but would appreciate your thoughts.320mm, 150mm and 270mm slim scales.
View attachment 444768View attachment 444769View attachment 444770View attachment 444771View attachment 444772
I didn't really get involved in the difference btw slim and a not-slim; the kit I bought off eBay didn't have option, other than 5 or 1 micron resolution.Robert - in retrospect, did you need the slim scales? I'm looking at ours and there seems to be plenty of space but would appreciate your thoughts.
The set for my lathe came from this supplier about 2 years ago and were spot onJust for the hell of it, three prices for what seems to be the same thing from the same supplier?
Pardon our interruption...
www.ebay.co.uk
www.ebay.co.uk
Putting together the set we need results in different final prices, too. My mind is boggling![]()
