Reman
- Bristol, UK.
I use carpet spray adhesive, cheap and easy to remove if you just spray one side. Spray both surfaces and let it tack and it gets harder to remove.
I tried that in the past, and the brand I used was quite "Persistent". It was taking me around 15 minutes with solvents and scrapers to clean it all off each time I wanted to change the paper. Problem was, If I didn't clean the glass thoroughly I'd get a build up of the stuff that would make the paper slightly uneven, And that made it multiple times more likely that I'd rip a hole in it.
I would make a paper clamp one end of the glass and a stretcher/clamp for the other end, has to be easier than faffing about with glues.
