sorry,should have said new or newish(sub 3 year)Old or new? Can't comment on the brand new but I had a Ranger about 6 yrs back and I thought it was a bit cack.
Very bad on fuel, like mid 20's on a run if you was lucky. Depends what you want it for I suppose
What he said!If you REALLY need the 3.5 tonnes tow capacity there's only one solution, dare I say it Land Rover 110 or 130 Double cab pick-up.
Not as comfortable and car like (bit of an understatement here) as the Japanese stuff but does the job in a workman like manner. All comes down to performance over comfort I suppose and your priorities.
looking for a 4x4 truck
would like 3.5ton tow capacity but all doublecabs are at most 3ton
looks like it comes down to the isuzu denver or ford ranger
anyone got any views on either??
regards
i should also have said no to theseIf you REALLY need the 3.5 tonnes tow capacity there's only one solution, dare I say it Land Rover 110 or 130 Double cab pick-up.
isnt a disco 3.5 tonnes
true but then disco's arn't crew cabs though.
200 quid difference in price between a ranger xlt and isuzu denver maxEarly ish Rangers had very low power engines, I believe the later ones have the newer direct injection engines.
Either way I would go for the Isuzu, been around for years and together with Daihatsu were the only real alternative to the Landy's when used for proper work.
Rangers are cheaper though so it is a price trade off.
The nissans and Mitsi's aren't bad, again the newer engines are much more economical if you can afford a late one.
MM
regards
