Yes i'm a production welder myself and i think i know a lot about operator fatigue and straining your wrist allready...what's the pricetag on that torch then?
Of course it's like anything. If you want the best you need to pay more for it. If the best isn't needed then you can save a few quid.It will in my opinion, but the 20 odd % price difference on an already upper price bracket torch is a bridge too far for most, even if the torch is subjectively better made.
You'd be mad to pay that. No need to go out looking for compatible oem watercooler.The water cooling unit compatible with my welder would be a Kemppi WU10, quick google at used machines says 550€ for a used unit. According to the manual there's also a TW300 interface between the cooler and welder, I am not entirely sure this is needed.
Any idea on what kind of pump would be suitable, Iif IRC it needs to be capable of lots of pressure. I work at a place that makes hot tubs and saunas and we have several electric water pumps.
You won't make a cooler for less than £100 if you want to use a procon pump and motor.Best and most reliable pump for a cooler is Pro-Con as used in Tweco and Bernard coolers. They are used in things like vending machines, and a couple of years ago I bought one complete with motor for £25. But if you can get electric pump for nothing that sounds even better!
Get hold of a stainless gastronorm catering container from Ebay to use as a tank, and something like a heater matrix from a scrap car to use as a heat exchanger, add some pvc hose, and connection fittings, and you have pretty much all you need for less than £100.
Exactly..........If you can stumble accross a pump for next to nothing.
Perhaps a fuel pump for a car, A quick look at a hardware stores website shows one for 60 euros which could do 5 bar (70psi) and 3l/min, or 3 bars and 4.5l/min
That was a great thread and a great example of a little diy cooler.I recently made a cheap cooler using a caravan pump from ebay. so far it has worked fine, but even when in use, I'll be welding less than 10% of the time, and so far the torch handle and coolant tank has remained cool. I have ordered a spare pump just in case though and long term reliability isnt known yet.
http://www.mig-welding.co.uk/forum/...torch-and-diy-cooler.65542/page-2#post-860698
