Craig-SM
- Heckmondwike
Fit a double rad of the same pipe fitting dimensions, and run it at a lower temp?
Why can't you take the valves off the existing pipes, fit elbows and short stubs, then refit in line valves? No destruction required.
first off what is the size difference between the old and new rads
if its 1-2" you can buy extenders and there is bigger extenders if needed
but also note if extenders are used you may need to change the valves as well
The current radiator is about 10 feet long in a bay window and the pipes are wedged/cut into the skirting board corners. Between the radiator itself and the pipe work it looks a mess.
He had thought about running a type 22 at half the height for the same length but silly money and still leaves the mess with the pipes so tight into the skirting. Instead he’s going to fit a 2m type 22 and replace the hacked up skirting as it’s bugged him since he moved in and it’s in a focal point so wants it looking neat.
the blades are verry thin so wont wreck the boards ive took hardwood floors up without ruining them
