Back in the day I had a 96 Ford Cougar with the 2.5 v6 Duratec petrol lump in it.This is a strange one, to me anyway.
Corolla 2Lt diesel turbo manual box
I can't remember when I first noticed this happening, but even going down hill when I take my foot off the excellerator the car feels like the brakes are being applied and it is very notable
First I thought it was a caliper siezed on. Then I thought it could be low pressure in tyre (s). However, if I put it in to neutral the 'braking effect' does not happen.
Is it possible that an engine or gearbox can cause this?
it could still be a seized caliper.... combined with engine breaking (ie. there will be a small amount of engine braking anyway, which will become more apparent when combined with seized rolling components). Probably worth jacking it up to check rolling resistance of each wheelThis is a strange one, to me anyway.
It's a dieselBack in the day I had a 96 Ford Cougar with the 2.5 v6 Duratec petrol lump in it.
It had zero engine braking and made a weird moaning noise on closing the throttle that they called 'moosing' on the forum.
The fix for' moosing ' was to restrict the idle air feed from a 1/2" pipe down to about 1/4" with a bit of extra smaller tube inside it + a hose clip to tweak the result.
Moosing stopped and I also got decent engine braking for free.
The point of the above is check your idle circuit (if any) for blockages, decayed hoses, engine breather gauzes etc. If there is no butterfly valve the idle fuel feed is too high
That I know.It's a diesel
my norton used to stop on a tanner if you backed the throttle off .drop a gear without revving it up and the back wheel would lock the crank was massive and heavyI noticed that with mine (650 V twin) rolling off the throttle is like putting the brakes on.
If I follow cars down big hills I'm watching brake lights all the way, but I have to keep my throttle open a bit else I would grind to a halt. I've never had a bike quite like it, mainly had Jap fours in the past though.I wish BMW made quad bikes, my Yamaha quad has no engine braking at all. Makes for a very interesting ride down hills
My t bucket had a V6 Essex Ford motor in it, coming into bends, back off the throttle, and the auto-box would downshift, every time. Plenty of engine braking in that thing, but the handling and ride was just too hairy for my liking. I moved it on and started another project.Back in the day I had a 96 Ford Cougar with the 2.5 v6 Duratec petrol lump in it.
As mentioned in OP if I put it in to neutral the 'braking effect' does not happen'. This eliminates caliper, or tyres being under inflated for example. It runs free with no resistance at all.it could still be a seized caliper.... combined with engine breaking (ie. there will be a small amount of engine braking anyway, which will become more apparent when combined with seized rolling components). Probably worth jacking it up to check rolling resistance of each wheel
My works POS has hill assist, it played up during the week. Felt like brakes were stuck onIs this car fitted with that brake assist system? If it is it could be on the blink.
Bob
